Hello,
Please how to bypass a condensation code error C21:00 for a TRV238E camcorder ? this error don't desapear even after many days, the owner sead that the dew sensor have been cleaned by alcohol!!:
any adeas to fix this?
2020, September 8 - 11:09
#1
Hi,
bypass dew sensor with, if I recall well, 1k2 resistor. As first remove dew sensor.
regards
Hi,
Thank you for your reply,
I'll try with this resistor value and I'll prvide a feedback ASAP.
Best regards.
10k !!!
Hi, it is possible the value is 10k, you should try, one of this values is OK.
regards
Hello guys,
Thanks god, the issue is fixed, with a 1k9ohm resistor (with two chirurgical welding points ;))
Thanks to you all especially to bluemoon who first approaches the wright interval with his suggestion of a resistor value of 1k2 ohm ( but not with 10k!!).
