Hello,
Please how to bypass a condensation code error C21:00 for a TRV238E camcorder ? this error don't desapear even after many days, the owner sead that the dew sensor have been cleaned by alcohol!!:
any adeas to fix this?
2020, September 8 - 11:09
#1
I found what you are looking for. I just finished fixing my Sony DRV-TRV120. The sony Error code says moisture I dried mine for months, Pulled all batteried and it still didnt work. I seriously left my camera in its bag Several Silica Gel bags in it (Remeber to NOT eat) for at least 2-3 months and it still did not work. I was looking to buy a new camera and thought I would look one more time for help. I found it!!! The solution to fix this problem was very hard and takes along time to fix LOL....just kidding The site says to turn off and remove all batteries and HIT the camera. I removed all batteries and hit the camera once with an open palm on the bottom of the camera. Gave it power and turned it on and NO MORE ERROR... I am not suggesting that you abuse your camera, try to dry it out and/or seek out Sony support and/or Warranty. This link has more people talking about this and other errors. Check it out. http://www.globalmediapro.com/av/messages/135625-3.html I have a Birthday party tomorrow so I am going to try this camera out fully tomorrow. I will give you more details after :)
Hi,
bypass dew sensor with, if I recall well, 1k2 resistor. As first remove dew sensor.
regards
Hi,
Thank you for your reply,
I'll try with this resistor value and I'll prvide a feedback ASAP.
Best regards.
10k !!!
Hi, it is possible the value is 10k, you should try, one of this values is OK.
regards
Hello guys,
Thanks god, the issue is fixed, with a 1k9ohm resistor (with two chirurgical welding points ;))
Thanks to you all especially to bluemoon who first approaches the wright interval with his suggestion of a resistor value of 1k2 ohm ( but not with 10k!!).
