Good afternoon,
I've been looking around to try to find 2 Diodes values on a Panasonic Tv TH-42PV62EH on a power supplu DPK SU2AV-0.
the two bad diodes are D411 and D596, i couldn't find the schematic or diagram nowhere, maybe one of you could help me.
Wish you a good day.
Thanks a lot.
Regards,
Hi. If your TV has chassis of GP9DE the diode D411 has to be ST02D-170 (B0BB17000009) and D596 has to be ERA15-10. I hope this information would help you.
Have a good one.
Hi Davyrex,
First of all thank you for your answer, regarding the chassis couldn't find your value but by looking on google it does look same chassis as GP9DE.
i attached a pictures of the two diodes maybe you can recognise them.
Thanks a lot for you help, have been looking around for months then i left the TV aside.
Highly appreciated.
What I found about those 2 diodes I will share it to you below in 2 different links.
D596 - ERA15-10
D411 - ST02D-170
Hope I could help with those 2 datasheet links.
Hi Davyrex,
Thanks again for your help, the D596 is definitely that one, the second link doesn't work. it seems anyway that Panasonic should have same references regarding their diodes, you found these two, there's no reasons they shouldn't be these values.
You are my rockstar Davyrex, tomorrow i go to the electronic shop, 4 solderings and fingers crossed the Tv is back on the shelf.
Thanks for everything man. i really appreciate your help ! and thank to ELEKTROTANYA which is for me one of the best electronic Forum i ever found, always usefull !
Wizzhard
Maybe it can help someone else, i found these diodes for 1.51euro with shipping at https://eu.mouser.com.
Mft reference : D411 : ST02D-170-7070 and the ERA15-10 is obsolet it's been replaced with : FR107GR0
WIizzhard
