Panasonic sa-ch74 cassette drive has stopped working
Prosim o radu tejto hifi veže.prestala mi fungovat kazetova mechanika .Tlačitka funguju na displeji sa zobrazi tape ,ale nereaguju ziadne tlačitka kazetaku hluche.Kontroloval som zdroj eliti su porjadku dva mali vysoke esr vymenene zdroj je poriadku .Prečistil som vsetky kontakty spoje.Na mechanike su prečistene tlačitkove spinače..
Please advise this hifi tower. My cassette drive has stopped working.
The buttons work on the display tape appears, but do not respond to any buttons kazetaku hluche.I checked the source elites are fine the two had a high esr replaced the source is fine.
I cleaned all the contacts of the connection.
The pushbutton switches on the drive are cleaned.
PushyG
PushyG picture
Hello,
Please download the service manual:
https://elektrotanya.com/panasonic_sa-ch74_e_eb_eg_sm.pdf/download.html
You can read the self diagnostic section on page 11 and error code list on page 12.
I mean, You problem is the cassette sensor switch (half).
Gábor
