Integrated Circuit Marking 65 = 5G J3P
14 posts / 0 new
rjcamatos
rjcamatos picture
Sirs,
I have a asus mainboard that have an integrated circuit labeled as: 65=5G J3P
This is an qfp-28 encapsulation.
I search on the places that i can remenber and i didn't found the datasheet on every where.
Thic IC is near a PCI EXPRESS 3.0 socket.
Where the hell i can find the datasheet?
Best Regards,
Ricardo Matos
BTS_szerviz
BTS_szerviz picture
hi!
maybe:  PWM CONTROLLER ATK1602GQW RICHTEK WQFN-28L  or RT6576DGQW
rjcamatos
rjcamatos picture
That's right its a PWM Controller, in this case is for the MOSFETs of 0,8V Raill, it comnect to source, gate and drain, now, gone try to find datasheet.
Thanks.
rjcamatos
rjcamatos picture
Ok, for annotations pruposes im gone attach some pictures of the circuit.
The first picture is the 0,8V raill, the IC at the bottom is the PWM Controller 65=5G, on the top of the imagem we have the inductor and low and high mosfet's.
The second picture, is the 1Volt raill that can be located right up of the 0,8V Raill (near the PCI express socket), the PWM controller is at the bottom and it is a 5E=5E, at the top we have the indutor and the high and low mosfet's.
BTS_szerviz
BTS_szerviz picture
Hi!
you are welcome!
A.
rjcamatos
rjcamatos picture
Number of pins match, encapsulation match , but no datasheet for that integrated circuit.
going to check out if connected to the MOSFETs of the  PWM circuits.
BTS_szerviz
BTS_szerviz picture
rjcamatos
rjcamatos picture
No, no......
It's a qfn-28 not qfn-20, im prety sure the ic is the one mentioned, but, what a hell there are no datasheet for that ic.
rjcamatos
rjcamatos picture
Nop, it's not that datasheet.
Datasheet says:
Dual Adjustable Output :
CH1 : 2V to 5.5V
CH2 : 2V to 4V
And the output voltage is 0,8V.
The main board os working well, im just analysing.
BTS_szerviz
BTS_szerviz picture
Hi!
What is the exact type of the mainboard?
A
rjcamatos
rjcamatos picture
I attach the picture.....
File csatolás:
rjcamatos
rjcamatos picture
Its an Asus vivobook e406M.
Thanks for response.
SzBálint
SzBálint picture
rjcamatos
rjcamatos picture
Thanks for response but,
Nop, not that One.
is qfn-28 or an qfp-28 , but prety sure is qfp-28 packet.
I read someware um the internet that is from richtech but richteck dont give informations.
Só, where can i find the datasheet of 65=5g?
