Studer A725 CD Player clean/grease
Does anyone know what type of grease or lubricant I should use on the rails and plastic rack/pinion that slides the drawer in and out? The drawer sticks and needs to be pushed to go all the way in.
And can I clean the rails and plastic rack/pinion with some isoproyl alcohol, or ?
PushyG
PushyG picture
Hi!
When you have plastic-plastic or plastic-metal connection, use this grease:
White Lithium Grease (lucasoil.com)
For metal-metal connection use fine instrumental oil or gun oil or blade oil (silicone based).
Never use solvent base cleaner to this surfaces. Only dry paper or textil cleaner or soap based cleaner.
Gábor
