HEATHKIT IP-2728 SUPPLY for 1 - 15 volts, measures 19 - 30 VDC. which transistor has failed? or what are the correct voltages on transistor terminals? (jumper on back switched makes no change) Add new comment Comments 2022, December 11 - 19:35 #506017 zsugori 15 years 6 months**** 1 q4,q5 bc107 bc108 0 2022, December 11 - 16:32 #506004 SzBálint 17 years 3 weeks**** HELLO! HEATHKIT IP-2728 https://elektrotanya.com/showresult?what=HEATHKIT%20IP-2728&kategoria=&k... Bálint 0
q4,q5 bc107 bc108
HELLO!
HEATHKIT IP-2728
