Philips 22RH457 speaker box, low sound level
I have two boxes Philips 22RH457. One gives normal sound level, the other has markedly lower sound level. For a quick check on anything different I measured impedance of both simply at the connection cable. Indeed, the normal one 6.5 Ohm the lesser one about 55 Ohm. Before starting to open the box, could anyone give an idea of the probable cause. The deterioration has been gradual because before both produced the same volume. Perhaps speaker failure, some condenser failure, etc. Please let me know. Many thanks in advance!
torokj
torokj picture
Hello Rudy,
https://elektrotanya.com/philips_22rh457_box6457_hifi_box_sm.pdf/downloa...
Is the lesser one  55 ohm really?
Probably the LS  403 woofer or soldering is bad.
Check and measure the woofer and the wires,soldering.
Good luck to repair
TJ
Rudy
Rudy picture
Hello TJ, indeed you are right. The lesser one is 8 Ohms. (also to me it seemed too high - I simply measured wrongly)
I understand from the manual how to remove the front plate but how to reach the 3-way filter? Where is it located?
Many thanks! (These are wonderful boxes - great sound!) Just in case here my email  >enentech@gmail.com<
Jaca
Jaca picture
Hello Rudy,
Probably must remove the biggest loudspeakar, and You can see.
https://www.youtube.com/watch?v=LtRvL12uP9I
about 2:45
Rudy
Rudy picture
Thank you so much - this has helped me enormously!
SzBálint
SzBálint picture
