My Beo hums whenever I plug in the turntable connector. The problem stops when you pull the cable. Plays the radio fine. Sounds good. I understand this is probably a capacitor problem. Is there a fix short of a complete capacitor replacement which is beyond my skill level. Is there a qualified repair service to send it to? Thomas
Is there a 3rd grounding wire coming from the turntable, and a binding post on the amplifier? Hum is usually caused by not grounding the turntable to the amplifier chassis.
