The single channel is twice as weak as the other channel. Everything else works. Add new comment Comments 2024, January 9 - 02:54 #531973 Shizo 15 years 10 months** Hello Try to change left and right input wire in output stage in PCB to eliminate problem is in preamplifier or power amplifier side. Look for burning resistor, bad soldering,in input serial electrolitic capacitor... 0
Hello
