Cambridge AZUR 840E Service Manual wanted
26 posts / 0 new
jpaudioa4
jpaudioa4 picture
Hi to all funs of Electronics. I am interested for Cambridge AZUR 840E preamp service manual. I would appreciate if someone can post a link for download or add this document at our database.
Thanks in advance for your attention and help.
Best regards,
John
jpaudioa4
jpaudioa4 picture
Hi Miki, (Kolya61)
Thanks for your attention. Sorry for my bad Hugarian but I undestood that you have the manual. You can send to it jpaudiolab@hotmail.com This is my mail address.
Once again, thanks a lot for your help.
Regards,
jpaudio
Kari
Kari picture
Hi John,
Its nice to read over your understanding of our "seldome" languige :-)...
It will be fine please if you can upload some documentations from your collection for our database too?
tnx in advance & best regards!
Kari
jpaudioa4
jpaudioa4 picture
Thanks for update but I already checked given files and they are far away from 840E. "W" model is a power amp, "A" model is intergrated amp with different preamp section.
Regards,
jpaudio
Kari
Kari picture
Hallo John,
OK-sorry, I didn`t checked these documents in detail, but possibly you will find that here: :-)
http://www.audiocircuit.com/Home-Audio/Cambridge-Audio/Azur-840-E
(Sorry, but my account is used for today..)
Greetings,
Kari
kolya61
kolya61 picture
Szia Kari!
Mond meg a Jpaudioa4 cimbinek,hogy meg van a service manual 2.88 mega pdf,de nem tudom hogy lehet neki átadni.
Miki.
exGelkás
exGelkás picture
Szervusz Miki!
Feltöltöd a Tanyára, és már szedheti is le a cimbora!
exGelkás
kolya61
kolya61 picture
Szia Ex!
De nem ponyimájet magyar.
SzBálint
SzBálint picture
szia kolya .
feltöltöd a tanyára,és a helyet ide bemásolod.
kolya61
kolya61 picture
Szia Bálint!
Nem szeretem amikor 150 letöltés van ,feltöltés meg egy sem!
Karinak akarok segiteni,ha már forditott,de először megkérdezem,hogy megérdemli-e?
Nem minden áron szoktam segiteni,azért ....!
Üdv Miki.
PS-Ha majd Nektek köll,szivesen!
SzBálint
SzBálint picture
szia:én például nem tudok feltölteni, igaz, küldtem be vagy 6-700 címhelyet, ahonnan le lehet tölteni klf anyagot.
Lehet, nem ismeri a lehetőséget.
kolya61
kolya61 picture
Szia Bálint!
Más sem ismeri!
Regisztrált vagyok és pontokért lehet letölteni.
Ezért várom Karit.
Most azt hiszem,bocsánatot kért ,hogy nem tud magyarul ,én meg bocsánatot kérek,de csak oroszul tudok.
Üdv kolya61.
File csatolás:
Kari
Kari picture
Hali Miki!
Ma volt par PM-valtasom a joemberrel, s kiderült, hogy mar regebben (is, + ma is) probalkozott a feltöltessel, de nem jött neki össze.
Mivel kerte is, hogy beavattassek, megkisereltem neki kisse leirni, hogy mint reagalhat a rendszere, de esetleg nem minden jelenik meg angliusul, tölem megkapta a vonatkozo magyar megnevezeseket...
Meglatjuk, sajat megadasa alapjan aktiv, segitökesz lenne mas hasonlo helyeken.
Batorkodtam biztatni, hogy gond eseten pm-ezzen akar Pihenek is, vagy irja meg nekem/ünk avagy a listara, stb...
Kari
kolya61
kolya61 picture
Szia Karesz!
Ez a beszéd,nehogy má.
Ha akar ,akkor fog is feltölteni.
Elsőre engem is szivatott,de a segitségetekkel .már úgy megy mint a karikacsapás!.....Igaz azt még nem próbáltam.
Miki
SzBálint
SzBálint picture
üdv: URAK vagytok.
pihe
pihe picture
Szia Miki,
Nekem úgy tűnik, hogy ez is A-s ( ilyesféle fent van itt a tanyán is), de ő egy E-s végűt keres.
Csak azért szólok bele, hogy a letöltésével feleslegesen ne verd magad költségbe azon a másik oldalon.
kolya61
kolya61 picture
Szia Pihe!
Tudom és láttam hogy nálatok is fent van.
Ezek a gépek tök egyformák,az E betüs csak előerősitő,az A teljes ,a W vég ,a D cd játszóval van ,stb.
Sémailag u.a. az E és A előfok.A csávó nem igen tudja.
http://www.cambridgeaudio.com/series.php?SID=35&Title=840+Stereo
Üdv Miki.
PS-nem pénzes,csak regisztrált tagok tölthetik le.
Felülről bal oldalon a második keresőt látod?
File csatolás:
pihe
pihe picture
Ok, én nem vágom ennyire, csak ő írta, hogy az A-s eltér.
ui: a harmadikra gondolsz?
A jó múltkor láttam már ET-s keresőt egy orosz oldalon... lehet, hogy épp ezen? :hmmm:
kolya61
kolya61 picture
Szia !
Hát igen a harmadik,az első az övék!
Arra gondoltam,hogy a külsők között a Monitor után a Tanya van!
Azért ez már elismerés!
Üdv Miki.
Kari
Kari picture
Szia Miki!
Az altalam belinkelt cimen email-t kell irni nekik(eppen megtettem), s ha meglesz a doksi ertesitenek, allitolag most nincs az adatbazisukban_ mar maskor is jartam igy, de emlekszem, hogy par het utan meg is jött, addigra meg mar alig remlett, hogy miert is kapok tölük egy levelet.
Igen, a kollega kisse szabadkozott, hogy "nemtudni jol magyarul erteni", de irta meg, hogy addig eljutott, hogy Teneked megvan, s az emiljere elküldhetned neki; ca. ennyi....
Erre irtam be aztan, hogy ez szep, örülünk neki, de ö is feltölthetne nehany doksit a gyüjtemenyeböl.
Jo ejt mindenkinek!
Kari
kolya61
kolya61 picture
Szia Haver!
Éppen ezt mogyorózom én is.
Nekem meg van ,az első lapját fel is raktam.
Ezért vártalak.
Nekem is ha kell valami ,onnan, akkor ki van irva 14.99 .
Szóval,érted?
Üdv Miki.
PS-néztem az adatait, 150 le ,0 fel???
Kari
Kari picture
Hali Miki!
No problem Mr_ertettelek Titeket a Balinttal is, ezert is irtam neki ahogy eppen-legföljebb megsertödik, megha ez nem is lettvolna celom.
Neztem en is "a nagy aktivitasait", de sajna nincsen egyedül, node legalabb udvariasan ir-ker...
Nekem minden esetre semmi közöm hozza, max annyi, hogy racuppantam, hogy mely hasonlot lathatja az adatbazisban, mert esetleg megsem nezte.
Kari
kolya61
kolya61 picture
Szia Karesz!
Tényleg nem Ő van egyedül,de ilyenkor jön rá,hogy milyen szar amikor nem tálcán van,amit keres.
Nekem azzal semmi bajom ,hogy nem tud magyarul,de azért ami potya ,az potya.
Ha esetleg jelentkezik akkor ird már meg neki légyszives,hogy cserébe kérem a SANYO JA-6155 power ampl. SM-jét ide a tanyára és akkor én is adom ami neki köll.
Üdv Miki.
Kari
Kari picture
Szia Mikus!
Pü-ben elküldtem neki...
Hüvös sert!
Kari
kolya61
kolya61 picture
Szia Karesz!
Спасибо!Тебе холодное пиво
Üdv Miki.
Kari
Kari picture
Hi John,
You can find the versions Azur 840A & W in the databanc_maybe it`s usefull for you...
Best greetings
Kari
