Bose link cable
Error message
  • The comment you are replying to does not exist.
Hi.
I need wiring diagram for 8 pin din or 9 pin din to Rj45 Bose link cable
hifista
hifista picture
Hi!
I think, this is the solutoin:
Klenja
Klenja  picture
thanks so much, i've looked at it but wirng diagram is from macintosh, won't risk and destroy the entire bose system (the best solution is to have a cable from the bose and measure with the multimeter.
hifista
hifista picture
Hi!
I haven't this type of Bose cable, but i have some ideas.
In this viring diagram  the pin 4 on the RJ 45 side is GND, the DIN side the 4 and 8 is the GND.  You can check in the equipments this with an multimeter.
What is the Bose device type, what do you want connecting? If you can find the schematics, maybe  will be an easyer way.
Hifista.
SzBálint
SzBálint picture
Klenja
Klenja  picture
thank you very much balint, i have read there but no one has diagram for 8 pin or 9 pin to rj45 unfortunately, i try to find for 3 days but found nothing, mostly for 13 pin (.
city217
city217 picture
Háj.
Itt nézted már, és mit akarsz összedugni?
https://www.google.com/search?q=8+pin+or+9+pin+to+rj45&client=firefox-b&...
soundLover
soundLover picture
BOSE LINK CABLE
I have a old Bose Lifestyle 18 DVD head-unit AV18 , a amplified subwoofer PS18, but have no cables.
There are so expensive online, like 50 pounds and more.
does anyone can give me the pinouts for mini-DIN 8-pin (Bose Link) to RJ45 cable please?
with numbers by position on each side of the cable.
If you see what I mean, tracing each wire from one position to the other side position.
Many thanks
Apreciate
