I'm looking for Samsung HT-TZ422 schematic diagram. Mine is for 110v power. Need to make it possible work with 220v. May be someone had done this? Or any advise would be appreciated.
hello
SAMSUNG HT-TZ422
https://elektrotanya.com/showresult?what=SAMSUNG%20HT-TZ422&kategoria=&k...
Thanks for replies. Actually we use additional 220v to 110v transformer-convertor, which we wanted to eliminate. I guess we would just keep using that way.
Hi,
You can follow 2 path:
- You can buy a high power voltage converter, for example: https://www.amazon.com/International-Power-Voltage-Converter-Transformer...
- You search a recycled power unit for this equipment (from european version), and change it.
Please, nothing use low power voltage converter, or voltage converter without transformer! These will destroy your device!
Gábor
Dear Anonymus!
Data:
solution:
50VA transformer for mains connection
https://www.ebay.co.uk/b/50va-Transformer/260831/bn_7023514097
https://www.ebay.de/b/Trafo-110V/bn_7005767216?_pgn=4
