Dewalt DCB 115 does not heat up
Error message
The comment you are replying to does not exist.
Hello, I have a problem with DCB 115, it does not heat up and the yellow lamp lights up.  The elements are in working order,Can you tell me which component will be damaged
Shizo
Shizo picture
Hello!
Too little informations
First: DCB115= Dewalt charger, none of our members know from model number what you want to repair.
What is the normal operation without battery ? When you attached to 230V the yellow lamp lights up? Or why say not heat up ?
P.S.In 80% of fault is not in charger, fault is in battery pack.
If battery pack voltage<13.5V some charger not charge it.
nika
nika picture
Then the charger is charging, if I connect it to this charger, the yellow LED lights up immediately
