Fender Bassman 200 makes whooshing sounds
Error message
  • The comment you are replying to does not exist.
I have a Fender Bassman 200 that makes a whooshing sound similar to a breeze or wind blowing across a open hot microphone with or without anything plugged into the input jack.
I got this amp from a friend of mine because I was a bench tech for years, but now retired.
I just downloaded the schematic for this amp but the print is too small to read.
Any help would be greatly appreciated.
Thanks in advance.
torokj
torokj picture
Hello Albass77,
Change the U1 opamp (TL072-it got noisy)
and check the power supply caps.
Anyway the pdf file can be enlarged,use the zoom function.
Good luck to repair!
tj
SzBálint
SzBálint picture
