Harman kardon pm655 sound goes away
Error message
  • The comment you are replying to does not exist.
Al conectarlo y después de un rato se le va el sonido que hay que hacer o revisar
PushyG
PushyG picture
Hi!
Check the idle current and DC offset settings according to the description. If it differs, adjust it. If it still turns off after this, the protection circuit still detects an abnormality, which mutes the input. This can be caused by a difference in the supply voltage or the output current monitoring.
Gábor
