Heathkit GC-1195 Grandfather Clock redesign the numeral segments
Error message
  • The comment you are replying to does not exist.
1. Are there any reliable LED upgrade kits for the numeral segments?  I have red reviews that report problems with existing
kits.
2.  OR What is the correct wattage for the miniature lamps supplied with the original kit?
I am an Electrical Engineer and have successfully built many heath kits.  If I know the electrical load presented by the original mini-lamps, perhaps I can design an LED equivalent.
Thanx.
torokj
torokj picture
Hello,
https://elektrotanya.com/heathkit_gca-1195-1_chimes_for_gc-1195-1187_clo...
The power supply voltage of the miniature lamps is 5V,dimmed by LDR1,so you can calculate the series resistors of the LED display.
https://elektrotanya.com/heathkit_gc-1195_grandfather_clock_sch.zip/down...
Good luck to modification!
TJ
