Mastech m890g multimeter shows 1
Error message
  • The comment you are replying to does not exist.
Hello there. I've got a, problem with four of my m890g mastech multimeters.
All of them are showing 1.
No matter what I m measuring or testing.
Ohm or voltage or amps.
The fuse is healthy.
The probs are ok.
I dont know what to do?
mindigehes
mindigehes picture
Hi,
This type is based on the 7106 IC. The 1 on the LCD means: A/D converter overflow... If the rotary switch is OK, replace the IC... If you have luck, there are holes for the 40pin DIP version. Just remove the old one... If there is no dip chip under the LCD, just a black glue dot, then remove it with a dremel....
proba
proba picture
Trash
