Panasonic LCD TX-65AX800E not turn on anymore
Error message
  • The comment you are replying to does not exist.
Hello.
When I turn on my Panasonic LCD TV, flashing green LED then off with flashing red LED 6 times…
At the beginning by disconnecting and reconnecting several times it ended up lighting up but now it is not the case anymore... If the situation is unexpected and it is not the anomaly, it is possible to refrain from using mercury.
manyizoli
manyizoli picture
Hi,
Your emmc is bad, you need change and programing a factory dump.
https://www.mjkelectronics.com/en/repair-service-mjk-electronics/795-pan...
