Philips 32phs4132 power supply faulty
Error message
  • The comment you are replying to does not exist.
Please help, R9101 0.27R open, 100pF 1kV burned, K6A65D shorted, SMD resistors open. What else needs to be changed?
mosomedve
mosomedve picture
Hello!
All parts need to change new one. SMD resistors are: 47R, 100R, 1Kohm, 1N4148, PT6003 or PT6005 6 or 8 pins. Some times the opto coupler bad also. Try to download power supply circuit diagram somewhere.
Laszlo
alexhez
alexhez picture
Hi,
minor correction, the PWM controller is PF6003 or PF6005. 10R (instead of 100R, if I am right) should be replaced as well.
Regards
