SMATO H160 welding machine cause electric shock
Error message
  • The comment you are replying to does not exist.
Hay
i m using DC invert welding machine since last 3 year, but now it give electric shock during weld, what's problem any one help me, or how I check, machine name is SMATO H160
Waiting for reply
binci
binci picture
What exactly are you doing when it shocks? Touching the case, the electrode, the workpiece or the connections? Or two of them at the same time? Are you wearing gloves? Have you checked the protecting earth wire (ohm meter between the case and the mains connector earth)? Have you tried to use the machine in different buildings? (Wiring problems of the building)
Jojo
Jojo picture
While touch work get shock
Jojo
Jojo picture
While touching the work get shock and also tester is glow at negative terminal of welding machine.
