Sony FH-150R tuner (ST-177R) AM band setup 9kHz to 10 kHz
Error message
  • The comment you are replying to does not exist.
Hello:
I have a Sony FH-150R (circa 1987) compact high density component audio system (Probably the E model, not sure because there is no longer a model/serial number label) and need to change the AM tuning from 9 kHz increments (Japan's AM / MW frequency standard) to 10 kHz (Americas' standard)
Is it by a combination of keys on the front panel or by a dip switch or other method on the inside?
I have the service manual, but unless I missed the information, it's not there, and I have not been able to find the User Manual
Best Regards
Robert
lcsaszar
lcsaszar picture
Hi Robert,
I am afraid the tuning step is programmed in the controller for the specific geographic area. You can't change it by any internal control.
Regards
Roberto Muller
Roberto Muller picture
That's what I think will be the final result, that it can't be changed, basically due to the era it was manufactured. The headunit that I have in my car can be programmed, but is Android.
Thanks
soltipityu
soltipityu picture
Hi!
Check the TC9302F-005 INH (pin 48) voltage and the pin46 Reference output.
https://pdf1.alldatasheet.com/datasheet-pdf/view/161501/TOSHIBA/TC9302AF...
(page -783-, -784-)
 https://datasheet-pdf.com/PDF/TC9172P-Datasheet-Toshiba-528824
(page 16)
