CROSLEY CORP. 155 SCH
68.7 KB
Looking for similar crosley manual?
CROSLEY CORP. 155 SCH service manual (1st page)
Preview of CROSLEY CORP. 155 SCH [1st page]
CROSLEY CORP. 155 SCH service manual (2nd page)
Preview of CROSLEY CORP. 155 SCH [2nd page]
    CROSLEY CORP. 155
AIWA RX-N757HR mini HiFi
Üdvözlök mindenkit! Keresem az AIWA RX-N757HR típusú mini Hifi kapcsolási rajzát, ha valaki tudna segíteni, hogy hol találom meg, vagy ha valakinek megvan és el tudná küldeni. A készülék a gombok megvilágításán kívűl semmit sem produkál, a fő tápok rendben vannak, zárlatra utaló jel nincs viszont a készenléti-és indítóáramkör nem működik. Előre is köszönöm a segítséget! Email:gykovacs026@t-online.hu Kovács György
NAD 3140 amplifier - power transistors getting hot
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
Kenwood GX-401EF2
szervusztok mesterek ...a Kenwood GX-401EF2 cd,cassette receiver bekotesevel kapcsolatban kernek tanacsot,...tehat a 12v,hangszorok hozzakapcsolasa, a gazdija sem tudta...es nemcsak toltore kapcsolta,hanem a polaritast is folcserelte
GEMIX RV24 5,1 ES erősitőben lakozó M62446AFP IC ről kellene valami adat
Szevasztok Errő az ic ről szeretnék kérni valamilyen adatot. Egy házimoziba van,valamilyen audióprocilehet vagy nemtudom,de ebből kellene hogy kijöjjön valami,de nem gyün.
