DENON DVD-2910 DVD-3910 DVD-955 DVD-5910 DVD-5910CI OST-F1062B
VIDEO-DVD - INFO-TIPS
526.0 KB
INFO-TIPS
Looking for similar denon manual?
DENON DVD-2910 DVD-3910 DVD-955 DVD-5910 DVD-5910CI OST-F1062B service manual (1st page)
Preview of DENON DVD-2910 DVD-3910 DVD-955 DVD-5910 DVD-5910CI OST-F1062B [1st page]
DENON DVD-2910 DVD-3910 DVD-955 DVD-5910 DVD-5910CI OST-F1062B service manual (2nd page)
Preview of DENON DVD-2910 DVD-3910 DVD-955 DVD-5910 DVD-5910CI OST-F1062B [2nd page]
    DENON DVD-2910 OSTF-1062B DVD2910 DVD3910 DVD955 DVD5910 DVD5910CI OSTF1062B DVD 2910 3910 955 5910 CI OSTF 1062 5910CI OST F1062B DVD-3910 DVD-955 DVD-5910 DVD-5910CI OST-F1062B
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
AIWA GX935Z
Sziasztok! Olyan kérdésem volna, hogy van egy videó és egy olyan csatornára van állítva hogy a kábelTv holmark(film)csatorna és a videó modulátorja egy frekin van igy össze gerjednek.Ha tudná valaki hogy hol tudnám átállítani a videót azt meg köszönném mert a tomsonét azt tudom de ezt máskép kel. Várom megtisztelő válaszotokat,Üdvözlettel:buszosgyuri!
AKAI VS-37EDG video működő képessé tehető ? A kollégám barátjáé . - Vissza adva . Újat vesznek .
Sziasztok ! A kollégám barátjáé a fent említett video . Szeretné a család megnézni a régi VHS videokazetta felvételeiket és a régi VHS filmeiket . Nosztalgiáznának egyet . A kollégám megkért ,hogy , ha lehet , hozzam olyan állapotba , hogy ezt megtehessék . Milyen esélyem van erre ? Érdemes belefogni ? A távirányító megvan hozzá . Készítettem néhány fotót , amit megpróbálok ide föltenni ! Ehhez a restauráláshoz kérem a segítségeteket ! Sajnos a video javításban minimális gyakorlatom van , inkább volt . Nagyon szépen köszönöm a segítségeteket . Üdv Jano http://kepfeltoltes.hu/141020/IMG_0019_www.kepfeltoltes.hu_.jpg http://kepfeltoltes.hu/141020/IMG_0021_www.kepfeltoltes.hu_.jpg http://kepfeltoltes.hu/141020/IMG_0023_www.kepfeltoltes.hu_.jpg http://kepfeltoltes.hu/141020/IMG_0025_www.kepfeltoltes.hu_.jpg http://kepfeltoltes.hu/141020/IMG_0027_www.kepfeltoltes.hu_.jpg http://kepfeltoltes.hu/141020/IMG_0030_www.kepfeltoltes.hu_.jpg http://kepfeltoltes.hu/141020/IMG_0031_www.kepfeltoltes.hu_.jpg
Grundig GV5395SV Szervizkönyv keresés!
Sziasztok! Kaptam egy rossz, a cimben szereplő tipusú videomagnot. Szeretném megjavitani mert szerintem szép készülék. Keresek bármilyen leirást és rajzot róla.Egyfolytában trackingol lehet hogy fejpucolással vagy beállitással meg tudom oldani de ha nem jo lenne többet tudni a készülékről.Köszönöm!
