DENON DVD-3800 OST-849
VIDEO-DVD - INFO-TIPS
77.5 KB
INFO-TIPS
Looking for similar denon manual?
DENON DVD-3800 OST-849 service manual (1st page)
Preview of DENON DVD-3800 OST-849 [1st page]
DENON DVD-3800 OST-849 service manual (2nd page)
Preview of DENON DVD-3800 OST-849 [2nd page]
    DENON DVD-3800 DVD3800 OST849 DVD 3800 OST 849 OST-849
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Samsung SV-270GX tunerről nincs kép és hang az AV kimeneten(Megoldva)
Üdvözlet mindenkinek! Megtaláltak ezzel a videóval, a hiba annyi, hogy tunerről nem ad képet-hangot az AV kimeneten.Illetve ez sem teljesen igaz mert ha a menüben beállítok egy csatornát addig van kép és hang amíg a menü látszik, de ha kilépek a menüből akkor eltűnik a kép és a hang is, a lejátszás ezután is tökéletesen működik.Van ennél gyerekzár, vagy reset lehetőség, illetve mi lehet még a hiba okozója? Tónió
THOMSON 6380C Nem veszi be a kazettát
Sziasztok! A fenti készülék magától nem veszi be a kazit, csak ha beletolom és bekapcsolom. Ilyenkor akár le is játsza, de a kivélnél lehet, hogy nem fűzi vissza. Eléggé rendszertelenül működik. Nem találok semmit ami a kazettafészek helyzetét érzékelné. A szokásos " kék" színű üzemmód kapcsolót már rendbe tettem, de semmi javulást nem hozott. Ehhez kérném a tanácsotokat. Köszönettel : Laci
Panasonic NV-HS825 (SJ422, FJ616, etc) kijelző
Sziasztok, a fenti típushoz keresek jó állapotú (lehetőleg nem emisszió szegény) kijelzőt, ha lenne még valakinek, akár bontásból is. Köszönöm, Steve.
