DEWALD RADIO MFG. CORP. 606 SCH
126.7 KB
Looking for similar dewald manual?
DEWALD RADIO MFG. CORP. 606 SCH service manual (1st page)
Preview of DEWALD RADIO MFG. CORP. 606 SCH [1st page]
DEWALD RADIO MFG. CORP. 606 SCH service manual (2nd page)
Preview of DEWALD RADIO MFG. CORP. 606 SCH [2nd page]
Equivalent if LM3886 ic
yes
Hi, friends.
        LM3886 ic original has vanished. China make don't work for more than 5 to 10 minutes. I will be very much thankful, if you suggest equivalent no to it
     Thanks.
rajanpaliwale@gmail.com
Orion SC1025 hálózati trafó primer oldala szakadt
Tisztelt Uraim!
Adott ez az Orion hifi, ami a fenti ok miatt üzemképtelen. A kérdésem, hogy van e a trafóban hőkioldó biztosíték, vagy újra kell tekercseltetnem?
Grundig YB-P 2000 not working on AM bands
Hi All,
Does anyone have any experience of working on this radio, its the small Grundig with a leather case designed by F.A. Porsche.
I have recently repaired one with corroded battery contacts which had obviously not worked for many years.
Its now working perfectly on FM, but MW and SW1 and SW2 have no reception, just noise.
If I leave the radio connected to a 5v power supply for many hours it does actually get some reception on AM, but its not consistent. I'm thinking the fault is somewhere in the 'front end', oscillator stage perhaps.
I have checked the AM coils and wave selector switch are OK and everything is visually in excellent condition.
Reading various reviews on this radio confirms they were sold very cheaply in the USA and many customers have complained there is little or no sensitivity on AM, whilst others say it works perfectly. This makes me wonder if there is a common fault on these which someone may know, before I start with my test equipment to try to find the problem...
Any advice would be much appreciated!
Panasonic SS-7100
A fenti erősítő csoda rajzát keresem ha valakinek megvolna nagyon megköszönném. Az élet furcsasága, hogy egy hete az utódját sax710 javítottam. Itt kaptam tanácsot és teljes a siker. Köszönet a jó csapatnak !
