FERROGRAPH LOUDSPEKER S1 SM
434.6 KB
Looking for similar ferrograph manual?
FERROGRAPH LOUDSPEKER S1 SM service manual (1st page)
Preview of FERROGRAPH LOUDSPEKER S1 SM [1st page]
FERROGRAPH LOUDSPEKER S1 SM service manual (2nd page)
Preview of FERROGRAPH LOUDSPEKER S1 SM [2nd page]
    FERROGRAPH LOUDSPEKER S-1 S1
BEAG HEC 45 Studio Monitor
Sziasztok! Szereztem egy pár ilyen szépséget, viszont a szintek már elég jól el lettek tekergetve benne. Ehhez szeretnék segítséget kérni olyantól aki már esetleg állított be ilyent! Segítségeket előre is köszönöm!
Trio-Kenwood: KR-3010 [Radio] S.N.962845 / Does not work, the final floor and prefinal floor defect with many burned component/
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Orion SE 260 jobb oldal melegszik
Sziasztok! Hozzám került a cimben szereplö szörnyeteg! Nem gyári állapotu, mert a toroid helyett hiperszil van benne amelynek emelt a tápfesze 42 volt. Müsorforrás nélkül kb 5 perc mulva langyos a jobb oldali végfok hütöbordája. Viszont müsorforrással szépen torzitásmentesen szol. Esetleg a nyugalmi árama lehet rossz? Emelt tápfesz nem okoz gondot? Letekert hangerönél semmi rendellenes zaj,illetve müsorforrás nélkül teljes hangerön sincs zaj. Valaki elkezdte modifikálni, de teljesen pozitiv irányba. üdv:atis
FMG12 tranzisztor helyettesítése...
Sziasztok! Egy eszközben a címben említett FMG12 -es dual tranzisztort (smt tok, közös emitter) kellene cserélnem, de ilyen alkatrészt nem találok sehol. Valaki tudna segíteni!? Akár helyettesítővel is ami talán kapható. Köszi!!!
