GRADIENTE D12-2,D20-3 SM
VIDEO-DVD - SERVICE MANUAL
15.9 MB
Looking for similar gradiente manual?
GRADIENTE D12-2,D20-3 SM service manual (1st page)
Preview of GRADIENTE D12-2,D20-3 SM [1st page]
GRADIENTE D12-2,D20-3 SM service manual (2nd page)
Preview of GRADIENTE D12-2,D20-3 SM [2nd page]
    GRADIENTE D-122 D122 D203 122 203 D12 D20 D12-2 D20-3
Akai VS-G405 hangnormaváltás
Sziasztok! Tudja-e valaki, hogy a fenti videón lehet-e kézzel hangnormát váltani (és hogyan), vagy automatikus? Köszönettel Attila
Daewoo Sh 9540 E.
Üdv mindenkinek! Daewoo Sh 9540 E.tipusú videomagnóhoz keresnék kapcsolási rajzot. Köszi a segitséget! József.
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Vezetékes vagy vezeték nélküli megfigyelő kamera?
Sziasztok! A közeljövőben szeretnék telepiteni egy videó megfigyelő rendszert. Már keresgéltem a kamerák tekintetében de nemtudom eldönteni,hogy melyik a jó megoldás.A vezetékes vagy a vezeték nélküli. Szerintem a vezetékes rendszer jobb minőségü. A kivánalmaim a következők:az érzékelendő távolág kb.7m. A jel továbbitandó távolsága:10.m. És természetesen éjjellátó is legyen (infra LED). A távollétemben történő rögzitést egy PHILIPS VR.400-as videómagnóra szeretném bizni. Nem tudom,hogy alkalmas e a kamera jelének autómatikus rögzitésére? A nevezett videómagnó alkalmas műholdvevő,dekóder,comcorder csatlakoztatására is. Létezett egy kilences helyiértékü kód is melyet a tv adó vezérelt(VSP/PDC). a kamera képtartalmának a megváltozásának a hatására is elindulhatna a felvétel? Mind ezekre kérem a segitségeteket és köszönöm a válaszotokat. Üdv:József
