Köszöntök mindenkit.
Először is elnézést ha nem jó a kategória.
A bajom ezzel a készülékkel az, hogy a dátum beállítás hibás. Az is érdekelne miért nem áll be magától DCF-el, kézzel kell beállítani.
Vissza a dátumra, beállítom kézivel év-hó-nap és csal. most ugye 2020.03.06 a van, ha ezt beállítom akkor szombatot ír holott péntek van. Ha egy évet visszamegyek az időben akkor péntek.
Valaki tudna ebben segíteni: Papírjait már letöltöttem.
.https://www.google.com/search?q=grundig+sonoclock+54-sc+5304+dcf&ie=utf-8&oe=utf-8&client=firefox-b
T, kipcsak
Trying to troubleshoot a issue with this radio and there are some SM / schematics on some websites,
but they are slightly different than this one.
Would anyone know a place to look where there are some Grundig people familiar with the products?
Hi All,
Does anyone have any experience of working on this radio, its the small Grundig with a leather case designed by F.A. Porsche.
I have recently repaired one with corroded battery contacts which had obviously not worked for many years.
Its now working perfectly on FM, but MW and SW1 and SW2 have no reception, just noise.
If I leave the radio connected to a 5v power supply for many hours it does actually get some reception on AM, but its not consistent. I'm thinking the fault is somewhere in the 'front end', oscillator stage perhaps.
I have checked the AM coils and wave selector switch are OK and everything is visually in excellent condition.
Reading various reviews on this radio confirms they were sold very cheaply in the USA and many customers have complained there is little or no sensitivity on AM, whilst others say it works perfectly. This makes me wonder if there is a common fault on these which someone may know, before I start with my test equipment to try to find the problem...
Any advice would be much appreciated!
Egy Grundig R2000-es került hozzám. Ismerősé, akit ráadásul érzelmi szálak fűznek a készülékhez, ezen kívül hölgy is az illető.
A panasz az volt, hogy nem szól. Szétszedtem és hiányzott a 63V. A táp:
A nyíllal jelölt biztosíték volt kiégve. Rövid méricskélés után nem találtam semmi különösebb problémát, így betettem egy 1.3 amperest (ilyen volt otthon, de mielőtt visszaadom veszek olyat mint ami gyárilag volt benne), bekapcsoltam és tökéletesen működik.
Először arra gondoltam, hogy túlhajtották szegényt, de a végfokok tápját a 2x21V látja el.
A biztosíték csere után járattam egy órát, semmi problémát nem tapasztaltam vele azóta.
Mit gondoltok, merjem visszaadni? Azért dilemmázok, mert nem szeretném visszakapni egy hét múlva, a biztosítékok meg nem szoktak csak úgy kiégni...
Rajz:
http://elektrotanya.com/?q=showresult&megnev=grundig&megnev2=r2000gb&kategoria=&kat2=schematics
DM
