GRUNDIG TEDDY-TRANSISTOR-BOY II 59 SM
2.7 MB
GRUNDIG TEDDY-TRANSISTOR-BOY II 59 SM service manual (1st page)
Preview of GRUNDIG TEDDY-TRANSISTOR-BOY II 59 SM [1st page]
GRUNDIG TEDDY-TRANSISTOR-BOY II 59 SM service manual (2nd page)
Preview of GRUNDIG TEDDY-TRANSISTOR-BOY II 59 SM [2nd page]
    GRUNDIG II 59 TEDDY TRANSISTOR BOY
grundig sonoclock 54-sc 5304 dcf év-dátum beállítási hiba
Köszöntök mindenkit.
Először is elnézést ha nem jó a kategória.
A bajom ezzel a készülékkel az, hogy a dátum beállítás hibás. Az is érdekelne miért nem áll be magától DCF-el, kézzel kell beállítani.
Vissza a dátumra, beállítom kézivel év-hó-nap és csal. most ugye 2020.03.06 a van, ha ezt beállítom akkor szombatot ír holott péntek van. Ha egy évet visszamegyek az időben akkor péntek.
Valaki tudna ebben segíteni: Papírjait már letöltöttem.
.https://www.google.com/search?q=grundig+sonoclock+54-sc+5304+dcf&ie=utf-8&oe=utf-8&client=firefox-b
T, kipcsak
Grundig YB-P 2000 not working on AM bands
Hi All,
Does anyone have any experience of working on this radio, its the small Grundig with a leather case designed by F.A. Porsche.
I have recently repaired one with corroded battery contacts which had obviously not worked for many years.
Its now working perfectly on FM, but MW and SW1 and SW2 have no reception, just noise.
If I leave the radio connected to a 5v power supply for many hours it does actually get some reception on AM, but its not consistent. I'm thinking the fault is somewhere in the 'front end', oscillator stage perhaps.
I have checked the AM coils and wave selector switch are OK and everything is visually in excellent condition.
Reading various reviews on this radio confirms they were sold very cheaply in the USA and many customers have complained there is little or no sensitivity on AM, whilst others say it works perfectly. This makes me wonder if there is a common fault on these which someone may know, before I start with my test equipment to try to find the problem...
Any advice would be much appreciated!
Grundig C8800 rádiósmagnón nem szól a rádió [MEGOLDVA]
Magnó rész szól, de a rádiókból semmi, UKW-n a sztereó LED se világít ki, ki se tudom szedni a NYÁK-ot, szervízesek anno ezt hogy javították? Előlapot leszedtem, de a hátulját nem bírom leszedni mert a végerősítő/táp hosszú panelja keresztbe van az alján..
Valmi tápfeszültséghiányra gondolok..
Grundig Car 200 bekapcsolása (nem kapcsol be)
Sziasztok! Azt szeretném kérdezni, hogy a fenti fejegység bekapcsol-e asztalon, kijelző nélkül. Nem kapcsol be hibával hozták, de nem találok benne semmi rendellenességet. Áramfelvétele 0,4A, de semmit nem csinál. Lehet, hogy a kijelzőre vár? Üdv.
