If you have any question about repairing write your question to the Message board. For this no need registration.
If the site has helped you and you also want to help others, please Upload a manual, circuit diagram or eeprom that is not yet available on the site. Have a nice Day!
Warning! If you are not familiar with electronics, do not attempt to repair! You could suffer a fatal electrical shock! Instead, contact your nearest service center!
Note! To open downloaded files you need acrobat reader or similar pdf reader program. In addition,
some files are archived, so you need WinZip or WinRar to open that files. Also some files are djvu so you need djvu viewer to open them.
hi
help help help!!!
Some one send my pics and my program eeprom for Haier l37v6- a8 ... but I said the programme eeprom is not good, bad ...(bbbbl)
look my post :
http://www.abcelectronique.com/forum/showthread.php?t=74265
Can you erase for all of us, the bad downlaod program (in the ElectroTanaya)!????
and, please!!!
I hope some one have this program eeprom of l37v6-a8-d or l32v6-a8 with mother board " 30tr04c ".
Do you have ?
Can you help me ?
B
Hi
I hope some one have this program eeprom of " l37v6-a8-d Haier " or "l32v6-a8" with mother board " 30tr04c ".
Do you have ?
Or some one can repared the eeprom program :
bad :http://www.megaupload.com/?d=SMP65600 ???
Can you help me ?
B
Ez a táp valami noname 58collos tv-ben lakozik enyhén szólva etet.Hibajelenség amivel érkezett ment kb félórát majd a tv készenlétre állt.Átforrasztva optok cserélve,+van egy hatlábu smd ic a készenléti és üzemi tápban ugyanis az egyik trafo PFC a másik ledek feszültségért felel a harmadik készenlét 5v+12v+24v ez az érdekes üresjáratban 5v ok 12v 11,8v ,24v csak 21v mérhető.Kivéve a trafo lábait meghajtva egy másik impulzus táprol a helyzet nem változik,az 5v 5,3,a12 az 12,2v,a24 az továbbra is 22v.A kondik és a két dioda cserélve.
Szerintetek elképzelhető hogy menetzárlatos a trafo 24v-os része?
If you want to join us and get repairing help please sign in or sign up by completing a simple electrical test or write your question to the Message board without registration. You can write in English language into the forum (not only in Hungarian)!
