Hello! Harman Kardon Receiver /amplifier AVR 65/RDS ! increases the Volume by it self some times (Suddenly) pse. advise .. Works Well otherwise! Best..Regards Rune..Sweden
A fenti géphez keresek sm-t. A tanyán lévők közt nem találtam. A barátunk is csak fizetőset mutatott. A masina egyik napról a másikra megkukult, egy szikra zaj sem jön belőle. Köszönöm
For your information to repair
Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown)
can be changed without any other servicing
Harman Kardon Receivers; Series AVR 2000,3000...
"Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time.
"Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V.
"Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there.
"volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V!
"everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function.
Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts.
So i hope i can help you...
cheers SG.
Harman kardon soundsticks III került hozzám. Végfok hibával. A végfok TDA8561Q.
Sajnos rajzom nincs hozzá.
A problémám hogy nem tudom szólalásra bírni.
A végfok IC-t kiforrasztvan a végfok IC 14 es láván 0V-ot mérek ami azt jelenti ha jól tudom, hogy készenléti állapotban van.
A végfok csere után kimenetein nincs fesz a 14 es láb kivételével minden jónak tűnik.
Ha berakom az IC/t akkor is ez a helyzet.
Tápok rendben, az IC lábain mérem a bemenő jeleket ha adok rá.
A 14 es láb feszültségét egy tranzisztor húzza le földre. A tranzisztor jó. Bázisán 0,66V.
A panelen nem lehet látni mi mivel van összekötve csak pár alkatrészt.
Ha valaki találkozott már ezzel a csodával, vagy van ötlete esetleg rajza azt megköszönném.
Üdv.:
Gy
