HISENSE TF2107HU CHASSIS ERSAG7.820.220A
3.5 MB
Looking for similar hisense manual?
HISENSE TF2107HU CHASSIS ERSAG7.820.220A service manual (1st page)
Preview of HISENSE TF2107HU CHASSIS ERSAG7.820.220A [1st page]
    HISENSE TF-2107HU CHASSIS TF2107HU TF 2107 HU ERSAG 820 220
Hisense lcd4033eu sm? táp?
Sziasztok Hisense LCD4033EU-hoz keresnék Service manualt, főleg a táprész miatt, ill ha valakinek lenne működő tápja, az is érdekelne.. Köszi Laci
Hisense LHD32K160WSEU nand mentést keresek
Sziasztok a fenti tv-hez keresnék nand flash mentést.
A flash:H27U4G8F2DTR
Alaplap: rsag7.820.5001/roh
Hisense PDH4217EU sm.
Üdv. mindenkinek! A Hisense PDH4217EU plazma tv szervízdoksiját keresem, de az LJ92-01200A panel rajza is segítene. Bontásból származó működő panel is érdekelne. Szép napot: majen
Hisense LCD TLM3233D (very white screen, Fault and cure)
Hello, I have this LCD TV which has a very white screen, the picture is visible. I could not find any fault on the CCFL Lamp inverter and was suspecting the T-Con panel of failure. The T-con panel is integrated in the control board. What i did is using "freeze it" cold spray i sprayed one of the IC's and it cured the fault. Perhaps the IC needs to be replaced. The part number is AS15-G. This component is not available for purchase in south africa and i would need to import it from china. This part is a LCD voltage buffer. Regards Angelos
