Valami nagyobbacska teljesítményű végfokra lenne szükségem...
Méricskéltem és szemrevételeztem már pár típust, de még nem döntöttem egyik mellett sem (egy Siva 2400-as már majdnem megtetszett...)
Egy topikon páran dicsérték a Füleki 1200-ast...erről kellene némi infó.
Ha valamelyikőtök használ/javított már ilyet, illetve, ha van róla rajz, kérlek, hogy osszátok már meg velem!
Előre is köszönök minden segítséget!
(Esetleg, ha van valakinek 4 Ohmon legalább valós 550-600 wattot leadó fölös végfoka kedvező áron, az keressen már meg privátban)
stonhy
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
Fent nevezett erősítőt táp hibával javítottam.Most már be lehet kapcsolni,de csak reset (direct + speakB)kombinációval.Ha ilyen módon bekapcsolom,normálisan működik,de nem lehet kikapcsolni.Lehet,hogy szoftver hibás a kicsike? Hogyan lehetne újra szoftverezni? Ha valaki tudna valami szoftot,vagy jig kábelt vagy kábel rajzot ,bár milyen infó,vagy tapasztalat jól jönne.
üdv.
GRUNDIG CF-5000 típusú magnódeck javításához keresem a képen látható fogaskereket.
Üdvözlettel: Gyula!
