KOERTING TRANSISTORKOFFER 32167 AROSA SM
1.4 MB
Looking for similar koerting manual?
KOERTING TRANSISTORKOFFER 32167 AROSA SM service manual (1st page)
Preview of KOERTING TRANSISTORKOFFER 32167 AROSA SM [1st page]
KOERTING TRANSISTORKOFFER 32167 AROSA SM service manual (2nd page)
Preview of KOERTING TRANSISTORKOFFER 32167 AROSA SM [2nd page]
    KOERTING 32167 AROSA
Denon PMA 525r letilt
Denon erősítővel kapcsolatban szeretnék segítséget kérni. Alap probléma az volt, hogy az egyik oldal bekapcsoláskor akadozva szólt kis ütésre megjavult. Gondoltam valahol KH-s.
Szétszedtem igazából nem  volt sehol látható forr hiba. Összerakás után sajnos egyáltalán nem működik. Villog a mute led majd gyorsabb villogás és ennyi. Átnéztem de nem találtam mit ronthattam el.
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Need schematicfor Soundcraft Spirit powerstation1200
Hi, anybody having schematic for Soundcraft spirit powerstation 1200.I tried the sites but the schematic is for spirit powerstation600. Kindly help me find schematic thanks
Rajan Paliwale.
Kenwood kdc-5090ry
halihó, hoztak egy kenwood kdc-5090ry tipusú autórádiót, amely a kijelzőn bekapcsolás után WAITING 4 (gondolom) hibakódot ír ki. Az elért forrasztásokat átforrasztottam, majd egyszer bekapcsolt. Azóta akármit csinálok vele, hiába, csak a kijelzön lévő hibakód (?) van. Estleg ha tudtok valamit erről, megköszönném.
