LUXOR BG1F14 ES531 ES531S TURNTABLE
4.0 MB
Looking for similar luxor manual?
LUXOR BG1F14 ES531 ES531S TURNTABLE service manual (1st page)
Preview of LUXOR BG1F14 ES531 ES531S TURNTABLE [1st page]
LUXOR BG1F14 ES531 ES531S TURNTABLE service manual (2nd page)
Preview of LUXOR BG1F14 ES531 ES531S TURNTABLE [2nd page]
    LUXOR BG-1F-14 TURNTABLE BG1F14 ES531 ES531S BG 14 ES 531
Sony STR DE 497 Készenléti Trafó.
Van egy Sony Házi Mozi Erősítő amiben a készenléti trafó nem működik de sajna sehol sem találom hogy a szekunder feszültsége mennyi lehet se a rajzon nincsen megadva sem a part listában sem a neten trafó szám alapján nem találok róla adatokat úgy látom eléggé titok övezi hogy a Sony nem veri nagydobra ennek az értékét .
Én 12V tippelek de inkább kérdezek mint le égessem a vezérlést.
NAD 3140 amplifier - power transistors getting hot
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
SONY HCD-H1700
Tiszteletem Mindenkinek! Fent nevezett hifi, vagy ehhez hasonlóhoz szeretnék kapcsolási rajzot, szervizkönyvet kapni.Vagy ha valaki tudná, melyik SONY hifi hasonlít ehhez, megírná. Előre is nagyon köszönöm.
Soundcraft MFXI8 zenekari keverő nem szól
Sziasztok! Hoztak javítani egy 2,5 éves Soundcraft MFXI8 keverőt. Természetesen már nem garanciás. A hibajelenség az, hogy bármelyik sávra dugok mikrofont, vagy vonal szintű jelet nem jön ki belőle hang se a masteren, se az auxon. Ha bekapcsolom a fantom tápot annak sem világít a ledje és az effekt részen sem világít semmi, csak a power led, a mute gombok ledjei, meg a solo. Sajnos rajzom nincs hozzá, de táp hibára gyanakszom, csak nem tudom, hogy mekkora feszültségeket kellene mérnem. A tápról egy 6 eres lapos kábel csatlakozik a panelra, ezen csak a test és 2 ér között tudok mérni +28, illetve -28V-ot, de gyanítom, hogy itt lennie kellene még más feszültségnek is. Azt nem tudom, hogy segéd táp van-e valahol még külön, de a táppanelről jövő vezetéken, csak ezeket a feszültségeket mérem. A tápon forr hibát nem látok, tranyók, diódák, ellenállások jónak tűnnek. Próbáljak meg egy újrakondizást? Bár mivel 2 éves múlt, meg nem egy gagyi cucc, így nem gondolnám, hogy kondi baj. A legrosszabb az, hogy rajz híján azt sem tudom milyen feszkókat kellene keresnem.
