LUXOR R3D8 1109105 RADIO CASSETTE
3.5 MB
Looking for similar luxor manual?
LUXOR R3D8 1109105 RADIO CASSETTE service manual (1st page)
Preview of LUXOR R3D8 1109105 RADIO CASSETTE [1st page]
LUXOR R3D8 1109105 RADIO CASSETTE service manual (2nd page)
Preview of LUXOR R3D8 1109105 RADIO CASSETTE [2nd page]
    LUXOR R-3D-8 CASSETTE R3D8 1109105 RADIO
Little help for Akai PM-750 repair (voltage selector)
Hi all,
I need a little help to repair my Akai PM-750 amplifier (part of system mx-750).
The voltage selector has broken and I don't know wich wires shoud I put together to get it work under 240V.
Service manual is no help, they just give spares parts...
Huge thanks to who could help me :-)
ELTA-8803 CLS
Sziasztok! ELTA 8803 CLS-házimozi kapcsolásirajzát keresem,esetleg olyan linket,ahol utána nézhetnék.Előre is nagyon köszönöm az esetleges segítséget:Yani.
Kenwood KA-3500 Integrated Amp BIAS Adjust
Hello, Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape. Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors? -- On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me. -- I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were? -- The service manual is on site here. Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read. I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty. -- Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2: Bellarmine
Denon D-Link kábel lerás (pin-out)
Két Denon DN-S1200 szeretnék összekötni 1 db RJ45-s kábellel (nem nem sima lan hálóztati kapcsolat).
Viszont nem tudom a lábkiosztást. Nem találok rá pin-out konfigot.
Tudja valaki hogyan kell krimpelnem az RJ45 csatit a  cat5e kábelre?
Köszönöm.
