MARCONI 181 RADIO SCH
Type: (JPG)
210.9 KB
Looking for similar marconi manual?
    MARCONI 181 RADIO
JVC CA-MXKB2 Locked
Sziasztok! A fent említett hifi, most már működik, csak a CD rész nem indul, mert ha megnyomom az open gombot azt írja a kijelző hogy LOCKED, mi a fene lehet vele, meg forgatja a lemeztartót, fejet is megemeli. Segítségeteket előre is köszi!
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
VT erősítőhöz keresek gombokat.(EA6383)
Sziasztok! Egy VT erősítőt szeretnék saját részre rendbehozni a gyűjteménybe, csak a képen látható az állapota. A gombokon kívül akár még szebb előlap is jöhet. Talán van elfekvőben valakinél. Köszönettel. Karesz.
STUDIOMASTER AX3500 végfok működése
Sziasztok! Nagyon elgondolkoztatott ez a nagy teljesítményű erősítő működése, kapcsolástechnikája. A végfokban párhuzamosan kötött 6db NPN 2SC5200 és 6 db PNP 2SA1943 végtranzisztoroknál az emitterre csatlakozik a + és - tápfeszültség, a collektorok pedig szigetelés nélkül vannak a hűtőbordára csavarozva. Normál esetben ez lenne akkor a hangszóró kimenet, itt viszont mindkét hűtőborda vastag vezetékkel le van földelve. A hangszóró testpontja is földelve van. A végfok zárlatos erősítőt sikerült megjavítanom, szól rendesen, sajnos szerviz rajzot nem találtam hozzá. Nagyon sok erősítőt javítottam már, de ezt most nem nagyon értem.
