MITSUBISHI DIAMOND-DPRO-2070SB NEC MULTISYNC FP2141SB SM
MONITOR - SERVICE MANUAL
3.4 MB
MONITOR
Looking for similar mitsubishi manual?
MITSUBISHI DIAMOND-DPRO-2070SB NEC MULTISYNC FP2141SB SM service manual (1st page)
Preview of MITSUBISHI DIAMOND-DPRO-2070SB NEC MULTISYNC FP2141SB SM [1st page]
MITSUBISHI DIAMOND-DPRO-2070SB NEC MULTISYNC FP2141SB SM service manual (2nd page)
Preview of MITSUBISHI DIAMOND-DPRO-2070SB NEC MULTISYNC FP2141SB SM [2nd page]
    MITSUBISHI NEC MULTISYNC FP-2141SB FP2141SB 2070 SB FP 2141 DIAMOND DPRO 2070SB
Mitsubishi Diamond Pro 2060u monitor sometimes does not turn on
Hello,
I have a monitor Mitsubishi Diamond Pro 2060u which is having a random problem.
Sometimes, it does not turn on. Sometimes I try a couple of times (pushing the On/Off button) and it started. Sometimes I try many times and it does not turn on.
When it star ok there is a metallic sound followed by a click and the green light is on.
When it does not turn on there is not any sound and the light is off.
Could it be a problem with the On/Off button? Or, Could it be a problem related with some capacitors in the power supply board?
I would appreciate any help with this problem.
Thanks and best regards,
Javier Martin
Mitsubishi lcd monitor hiba
Van egy mitsubishi diamondcrysta RDT1710V monitorom modelszáma L174F Szóval röviden bedugom és semmi se visszajelző led se semmi Szétszedtem sehol nincs semmi kiégve (vagyis semmi látható nyoma nincs olvadásnak égésnek puffadó kondiknak) Valaki tud segíteni hol lehet a gond? (arra már rájöttem hogy nagy valószínűséggel táp de ezt nem ártana kicsit szűkíteni) Előre is köszi minden segítséget
Mitsubishi FD730U error codes ?
Hi,
I've one mitsubishi FD730U projector that stop working after 2 hrs in power on. The led error code is :
POWER LED blinking green/red  and STATUS LED blinking 3x time green and one time red.
I can't find the error list on internet. Can you help me to find the meaning of this error code ?
Thanks.
