EAG AV760C csöves erősítőben milyen szerepe van a végcsövek előtti kis trafónak?
Estleg kihagyható a kapcsolásból?
Köszönettel:Csaba
Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Ezzel az erősítővel az a gond, hogy az egyik oldala nem szól, a másik oldala meg sípol. A kimeneten 1,1V-ot mérek, a relé meghúz. Amelyik oldal nem szól, az bekapcsoláskor pattan egyet. Mi viheti be a végfokba a sípolást, a végfok maga? Ebben egy SVI3205 ic van, ha jól emlékszem. Ez most lehet végfokhibás? Lehet szerezni ilyet?
A címbeli hifitornyot hozták hozzám javítani,hogy nem szól,csak búg.
A hangfalkimeneten kb 9v egyenszint mérhető.A végfok tipusa :AN7161(2 db).
Mindkettőt cseréltem.A hiba maradt ugyanaz.Áramkörét átmérve nem találtam hibát.
Van valami ötletetek? Fejhallgatót bedugva az szól.Ilyenkor eltünik az egyenszint a hangfalkimeneten.A fejhallgató meghajtása külön lábon történik.A végfok úgy néz ki,már korábban is volt cserélve a forrasztásból ítélve.Esetleg nem ugyanazt a tipust rakhatták bele?
