NATIONAL SA-51H SCH
2.5 MB
Looking for similar national manual?
NATIONAL SA-51H SCH service manual (1st page)
Preview of NATIONAL SA-51H SCH [1st page]
NATIONAL SA-51H SCH service manual (2nd page)
Preview of NATIONAL SA-51H SCH [2nd page]
    NATIONAL SA-51H SA51H SA 51 51H
JVC HX-5 hi-fi TEST -üzemmód belépés hogyan?
Sziasztok! A dokumentáció https://elektrotanya.com/jvc_hx-5.pdf/download.html 49. oldalán lévő procedurát akarom végrehajtani, viszont sehol sem látom leírva az 1. lépést, amely szerint a processzort át kell állítani TEST - módba. Valakinek sikerült már ez ?
Kenwood KA-3500 Integrated Amp BIAS Adjust
Hello, Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape. Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors? -- On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me. -- I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were? -- The service manual is on site here. Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read. I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty. -- Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2: Bellarmine
Thomson DPL-580HT Készülék néma , sötét a kijelző is.
Üdvözletem Tisztelt Mesterek! Tanácsot , segítséget kérnék. Az említett Thomson DPL-580HT géppel bajlódok. Hálózatra csatlakoztatva a készenléti led világít, kapcsolót nyomva indul, feszültségek megközelítőleg jók. Kikapcsolni nem lehet , csak kihúzni , de ismét indul. Kijelző egység tápja , feszültségei magasak. Pl:IC-103 stab. be és kimenetén azonos feszültség (5V) mérhető,a kisütő ellenállás miatt , tehát az IC-101 Microcontroller (HT48R05A-1) nem megy. A meghajtón Q102 (PT6315)-n is magasabb feszültség mérhető, 24V helyett,31V. Kérnék segítséget a tovább lépéshez. Valakinek van bontott gépe? Érdemes tovább bajlódni vele? Rajz a Tanyán van, kijelző részt nem tudtam úgy kicsinyíteni hogy a topikba mellékeljem. Előre köszönve a segítséget: Öreg Tom
T-box MA 120 aktív hangfal erősítője beteg
Kedves Kollégák! Leginkább egy rajz lenne jó ehhez a készülékhez.http://www.thomann.de/gb/the_box_ma120_mk_ii.htm Két db TDA7294 van benne...az egyik a saját hangszóróját hajtja, a másik ki van vezetve egy külső passzív ládához. A saját végfok ki volt durranva és vitt magával pár smd ellenállást... Ezeket érzés szerint pótoltam...(jelentéktelen helyen voltak) Tudom, hogy ez a leggyakoribb vég IC, de én nem használtam (jobb szeretem a diszkrét végfokokat)...nézegettem a gyári rajzot... Mindkét IC-re igaz, hogy a 9-es lábon 1V, a 10-esen 2V egyent mérek (stby és mute) szerintem ez kevés. A 2-es lábakon ott van a jel, de a kimeneteken semmi... A sok kis sűrű smd között igen nehézkesen mérek, de szerintem a 9-est és 10-est fel kellene húzatnom tápra... Jól gondolom??? Hány KOhmmal??? Ahogy néztem, van rajtuk egy-egy 10 mikrós elkó a test felé, egy-egy 6K körüli ellenállás és ezen egy visszirányú dióda... Ha valamelyikőtök tudna szerezni egy pontos rajzot azt nagyon megköszönném!!! stonhy
