NEO TV-1400SB
TV - EPROM
Type: (E2P)
1.1 KB
EPROM
Looking for similar neo manual?
    NEO TV-1400SB TV1400SB TV 1400 SB 1400SB
LED TV NEO LED-2202FHD It does not work, the front LED off ,power supply is OK
Mark:NEO LED-2202FHD
Model:LED-2202FHD
Chassis (main board, components): 17MB60-3 flash 25Q80
LCD Screen/Panel :: LC215EUN (SC) (A1)
More informations:   Power supply 17PW05-2
   _SN : 6694377 100624
It does not work, the front LED off, the power supply is ok.It was software on usb several times, periodically every 2-3 months and it worked, finally it was left with the st.by LED off, that's why I-m thought about flash memory. Thanks a lot!
Panasonic Viera NeoPDP pld. TX-42G15E vagy TX-42GW10 stb. SM?
hello mindenkinek! Panasonic TX-42G15E NeoPDP Plasma-TV-hez keresek SM-et (service manualt). Leginkabb a service-menu miatt. Valami hasonlo is jo lenne, pld. TX-P50GW10 TX-P46GW10 TX-P42GW10 TX-P46G15E TX-P50V10E TX-P42V10E TX-P50V10E TX-P54Z1E TX-P46Z1E ... Elöre is köszi!!! MOst olvasom, amerikában TC-P... neven futnak. De még igy se talalok semmit... :( (Ja, magyarul, németül, angolul is jo!)
Neovo EPT 4210 AP-hez plazmához keresek távot_Megoldva IRC81758
Sziasztok, a fenti plazmához keresek távot, ill. IRC számot stb. A Belson BSV 4251-el ekvivalens, ha minden igaz. Köszönettel. Imre
NEO TV-2132TX.
eeprom tv NEO TV-2132TX..procesor:TDA9352PS.N2.3I
