Schematic diagram for portable player Thomson TM 9670
3 posts / 0 new
smith666
smith666 picture
Hello everybody in Hungary,
I am looking for schematic diagram of portable player THOMSON TM9670.
When I connect an USB drive into the machine, the normal supply voltage 5.5V drops to approx. 2.0V in dependency of each usb drive. The player reports that no usb is connected.
I found out that power supply circuit comes from transistor D882L – from pin No.3 which is base pin. This doesn’t make any sense to me. I would expect it should be connected to collector or emitor pin. Therefore I need schematic diagram or service manual for this player.
Thank you in advance for any help.
Regards,
smith666
Jaca
Jaca picture
Dear smith666,
If You need schematics, try the Wanted box in right side: https://elektrotanya.com/rec_wanted
Regards,
Jaca
smith666
smith666 picture
I did it,
Thank you Jaca yes
