HEATHKIT IP-2728 SUPPLY measuring 19 to 30 volts on all radial dial settings.
HEATHKIT IP-2728 SUPPLY for 1 - 15 volts, measures 19 - 30 VDC.
which transistor has failed?
or what are the correct voltages on transistor terminals?
(jumper on back switched makes no change)
zsugori
zsugori picture
q4,q5 bc107 bc108
SzBálint
SzBálint picture
