ONKYO TX-SR574 SM AND PARTS REV1
9.6 MB
Looking for similar onkyo manual?
ONKYO TX-SR574 SM AND PARTS REV1 service manual (1st page)
Preview of ONKYO TX-SR574 SM AND PARTS REV1 [1st page]
ONKYO TX-SR574 SM AND PARTS REV1 service manual (2nd page)
Preview of ONKYO TX-SR574 SM AND PARTS REV1 [2nd page]
    ONKYO TXSR-574 AND REV-1 TXSR574 REV1 TXSR 574 REV TX SR574 TX-SR574
ONKYO TX-SR444 házimozi erosito hibakód
Sziasztok. Ismét egy erosito kérdéssel fordulok hozzátok. Az ONKYO bekapcsolás után tutatja hogy milyen a hang beállitás /Volume 14/ és utánna bejon ez a hibakód amit a képen is lehet látni. Tudnátok segiteni ilyenkor mi a teendo? Koszi a válaszokat.
Udv: Gyuri
ONKYO TX-DS494 low volume problem solving experience
Hello. here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494. In order to sell this amplifier I had to check if all the outputs and all the functions works properly. On the back of this amplifier you have to frontal output : A and B. I connect a pair of speaker on A output : no problem. I can adjust volume. when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize. With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated. I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays. I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly. here is my experience in repairing an amplifier
Onkyo TX-7520
Sziasztok! Onkyo TX-7520 manuáljára lenne szükségem ha valakinek megvan köszönöm.
ONKYO TX-DS797
Kedves kollégák! Tanulságos hiba megoldását szeretném közzétenni, ha valaki találkozik eme jelenséggel, / könnyen lehet, hogy típushiba/ egyszerűbb lehet a megoldás. A hibajelenség: Minden működött a gépen csak éppen egy hang nem jött ki a kimeneten. Táp, végfok minden jó volt, a hűtő ventilátor nem ment. Gyanús volt, hogy valami tiltás az oka a jelenségnek. A Main circuit PC board nevű, "U1" jelű panelen található memória kapacitás nyák felőli oldalán egy pici rozsdafolt jelezte, hogy kilyukadt. A kigőzölgő elektrolit a lyukgalvanizálást szétmarta több ponton. A pontok vezetékkel való pótlása és a kondi csere után a hiba elhárult. Laszlo 61 :D
