ONKYO TX-SR603 SR603E SR8360 SM AND PARTS
12.4 MB
Looking for similar onkyo manual?
ONKYO TX-SR603 SR603E SR8360 SM AND PARTS service manual (1st page)
Preview of ONKYO TX-SR603 SR603E SR8360 SM AND PARTS [1st page]
ONKYO TX-SR603 SR603E SR8360 SM AND PARTS service manual (2nd page)
Preview of ONKYO TX-SR603 SR603E SR8360 SM AND PARTS [2nd page]
    ONKYO TXSR-603 SR-8360 AND TXSR603 SR603E SR8360 TXSR 603 SR 8360 TX SR603 TX-SR603
Onkyo DX-7333 CD player sometimes doesn't recognize CDs
I have a Onkyo DX-7333 CD player, which sometimes doesn't recognize CDs. I don't think it's a laser pickup (KSS-213C) problem, because when it recognizes the CD, it plays it without a problem, even very scratched ones. The next thing is, it should play CD-RWs, but it doesn't even recognize them. I think it needs adjustment There are two pots on the main PCB - Focus Gain R123 and Focus Offset R112. Also there are two test points: TP1 4 pins, first pair labelled Tracking Gain, second pair Focus Gain TP2 2 pins labelled RF Out and VC But in the service manual is no description, what should be measured on the test points and how to set Focus Gain and Focus Offset. In the attachment is a cut out from the schematic, where the test points and adjustment pots are. Please if someone knows, how to?
ONKYO TX-7420
Sziasztok! A jelenség a készüléknél, hogy a rádiótuner frekvencia kijelzése, vagy a frekvencia 0.15Mhz-el el van tolódva. Tehát 100.8Mhz helyett 100.95-öt mutat. Mi lehet a gond? Ha esetleg rajzzal is tudna valaki segíteni, nagyon megköszönném. Köszi!
Onkyo TX-L20D service manual request
Can anyone help me with this service manual?
I have a unit with damaged Ethernet port.
Onkyo TX-NR509 DSP hiba ??
Van egy Onkyo TX-NR509 erősítő ami ugye a jellegzetes DSP hibával jött hozzám! DSP chip újra golyózva de még mindig nincs hang a HDMI oldalon!
A netet böngészve arra jutottam hogy a DSP chiphez tartozó firmware lehet a hibás ezt kéne újra írni...de sajnos ehhez nekem nincs technikám...
Valami miatt nem tudok USB ről sem frissiteni mert egyszerűen a menüben nem aktív az a menüpont ahol el lehetne végezni a frissítést  ezt mondjuk nem értem miért nem engedni?
Valaki ebben tudna nekem segíteni?
CSatoltam három képet hogy mit ír ki ez erősítő ha megnézem rajta a firmware verziókat , ugye a DSP nél csak ?????? jelek vannak ami hiba...
