PHILCO DVPP601 PORTABLE DVD SM
VIDEO-DVD - SERVICE MANUAL
1.8 MB
Looking for similar philco manual?
PHILCO DVPP601 PORTABLE DVD SM service manual (1st page)
Preview of PHILCO DVPP601 PORTABLE DVD SM [1st page]
PHILCO DVPP601 PORTABLE DVD SM service manual (2nd page)
Preview of PHILCO DVPP601 PORTABLE DVD SM [2nd page]
    PHILCO DVPP-601 DVD DVPP601 PORTABLE DVPP 601
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Panasonic NV-HS 1000EGC nem adja ki a kazettát
BUÉK, Tisztelt Fórumtagok!
Az ünnepek alatt elővettem a néhány éve félretett SVHS videomagnómat a topikban nevezett hibával - hátha átvette a műhelyszagot -, hogy lesz időm,ötletem a megoldásra, de nem jutottam előre. A kazettát bevette befűzte a szalagot, felpörgött és leáll. Minden Power On megnyomásra ugyanez újra és újra. Mechanikai problémát nem látok, a csúszópályák is rendben vannak. A kazettát már nem tudtam kivenni normál módon. A készülék nem agyonhasznált, kifejezetten jó állapotú. Lehet ennek oka táphiba, kondi száradás?
Javított valaki ilyen VCR-t ezzel a jelenséggel?
Köszönöm a hozzászólásokat előre.
Üdv: mayeri
Daewoo DV K885k
Üdv mindenkinek. A fenti videóhoz keresek kapcsolási rajzot. Ma kaptam ajándékba, és az a hibája, hogy se a fejmotor nem forog, se a capstan. Gyanítom, hogy 1 tápfesz hiányzik, de még nem szedtem szét. Köszi az LG user manual-t, probléma megoldva. Már a capstan forog, csak a fej áll.Le volt szakítva a csatija a capstan motornak, csak vissza kellett forrasztani. Attila
FUNAI 31D-250 kiadáskor nem húzza vissza a szalagot ( Kész )
Sziasztok! Ezzel a videóval az a gondom hogy nem húzza vissza a szalagot, amikor kiadja a kazettát. A kuplungnál nyújtottam a rúgón de semmi változás, és még kipucoltam a mód kapcsolót is. Lejátszás közben is gyengén viszi a szalagot, de még jó, gyors tekerésnél jó. Mit nem vettem észre?
