Üdv' Mindenkinek! Kihívtak valahova tv-t behangolni. Ott nyögte csak be a tulaj, hogy egy szállodai Philips. Adott ugyan valami cetlit hat számjeggyel, meg hogy mute, de nem sikerült dekódolnom. Most ki a hülye? Mert ha én, akkor nem jár kiszállási díj, ha a gazda, akkor igen. Mindegy, kértem háromezret, rosszul volt. Régi ügyfelem, gondoltam jó fej leszek és megoldom, PERSZE CSAK AKKOR, HA VALAKI SÚG NEKEM!
Dear Expert
The details of my TV is as follows
1. Philips 40PFL4707/F7 Manufactured March 2012
2. SMPS Board BA21P6F01 01 1
3. SMPS board has a sticker that says A21P6MPW C 7219720
4. This is a 110v Mains Supply TV sold in USA
5. I imported this from USA into my country where we have 230V.
6. I have a simple winding transformer that converts 230v to 110v
The TV has been having this problem. Here are the steps
1. Mains power on
2. Front panel white led blinks 6 times
3. Philips logo display
4. TV shuts down immediately
5. Nothing happens. If i press power button on TV or remote nothing happens
6. Have to power off and then wait for few minutes to experience same repetition.
Last two days, tried several times, only once the TV started and after 10 minutes it did auto shutdown as there was no input signal connected.
Does this indicate issues with SMPS or main cpu board ? Even if its faulty, how did it start once ?
More testing done as follows
1. Removed all connectors. Cleaned all three pcb with liquid cleaner. Cleaned all connectors externally and internally ( holes) using painting brush. Allowed everything to dry.
2. Reconnected
3. Started. This time, went past the Philips logo. I could connect a macbook via HDMI and play youtube videos on the TV for ~1 hours.
4. Using remote, entered service mode and initialized ( factory reset) the TV
5. For 1 hours of proper run, measured voltages. LED+24v was showing properly at 24v, AL+3.3v was at proper 3.3v and the P-ON-H1 was properly at 3.3v
6. After about 1 hrs, the screen shut down. The LED+24v is showing at 6v, AL+3.3v at 3.3v and P-ON-H1 is a 0v. This indicates the main cpu board has turned off the P-ON-H1 signal.
7. Power off, wait for 2 min. Power on... same philips logo and TV shuts down. Problem repeats.
8. Firmware is Code TVNB010_00_PF_XX91_BA PIC code U10_CM08:_40A_C7W_R_02. Did a google search and found no references if this firmware needs any upgrade.
requesting experts next steps to root cause the issue. I suspect the main board is bad and the SMPS is good. What if I manually put a wire from AL+3.3v to P-ON-H1 ? will the TV be on or is it risky for the main cpu board ?
I am attaching the service manual for this TV
Helló mindenkinek. Egy Philips tévével akadtak gondjaim, a modellt nem tudom, csak a sasszi látszik a hátulján ami FL1.17. Amikor hozzám került néha elsötétült a képernyő, majd újra működött rendesen, és mind igy. Kibontás után rájöttem, hogyha mozgatom a TXT-100Hz modult visszajön a kép. Nekiláttam tehát átforrasztani a rossznak tűnő forrasztásokat, többek között a TDA4680-at is. Miután ez megtörtént a tévé rosszabb lett mint volt, éspedig bekapcsoláskor a képernyő kifehéredik, belép a védelem és a tévé kikapcsol. Mérések után rájöttem, hogy a 3 darab TDA6101 nincs vezérelve a TDA4680 által, aminek a kimenő lábain kb. 0,3V van. Átnéztem a forrasztásokat nagyitóval de nem láttam, hogy valahol összeérnének. A kérdés az, hogy ez a TDA4680 tönkremehet-e a forrasztásoktól, vagy mi más történhettet? Van-e valakinek valamilyen ötlete? Más TDA4680-am nincs, hogy kipróbáljam. Mindenkinek előre is köszönöm a választ.
Elakadtam egy Philips LCD t-con panel javításában. A készülék néha (ritkán) tökéletesen működik, de többnyire csak háttérfény van, kép nincs.
A t-con panelen a gamma korrektor ic BD8139EFV nem működik. A tápfeszültségei rendben vannak, de a kimenetein csak egyenfeszültség van - a szkóp meg sem rezdül.
A bemenete - ha jól értem - I2c buszos vagy valami hasonló. Órajelet megkapja az OSC lábon, de az SDA és SCL lábakon semmi. Bárhogyan méregetem a panelt, az adatbusz csak egy eepromhoz csatlakozik, máshol nem találom. Sem az LVDS kábelre sem a panel közepén lévő sharp procira nem csatlakozik.
A T-con rajzát nem találom sehol, de a BD8139 rajza fent van az alldatasheet.com -on.
A T-con feliratai: TW10794V-0 7C9F X3593TP
A proci rajta Sharp Eagle2
A kijelző típusa: Philips LK315T3LZ53
Ha van ötletetek mit mérjek vagy cseréljek, ne kíméljetek!
A tv típusa: Philips 32PFL5522D/12 Chassis:LC7.2E LA
