PHILIPS A10PTV-2.0-PAL CHASSIS
27.2 MB
PHILIPS A10PTV-2.0-PAL CHASSIS service manual (1st page)
Preview of PHILIPS A10PTV-2.0-PAL CHASSIS [1st page]
PHILIPS A10PTV-2.0-PAL CHASSIS service manual (2nd page)
Preview of PHILIPS A10PTV-2.0-PAL CHASSIS [2nd page]
    PHILIPS CHASSIS 10 PTV PAL A10PTV 2.0
40PFL4707 Philips logo and shutsdown
Dear Expert
The details of my TV is as follows
1. Philips 40PFL4707/F7 Manufactured March 2012
2. SMPS Board BA21P6F01 01 1
3. SMPS board has a sticker that says A21P6MPW C 7219720
4. This is a 110v Mains Supply TV sold in USA
5. I imported this from USA into my country where we have 230V.
6. I have a simple winding transformer that converts 230v to 110v
The TV has been having this problem.  Here are the steps
1. Mains power on
2. Front panel white led blinks 6 times
3. Philips logo display
4. TV shuts down immediately
5. Nothing happens.  If i press power button on TV or remote nothing happens
6. Have to power off and then wait for few minutes to experience same repetition.
Last two days, tried several times, only once the TV started and after 10 minutes it did auto shutdown as there was no input signal connected.
Does this indicate issues with SMPS or main cpu board ? Even if its faulty, how did it start once ?
More testing done as follows
1. Removed all connectors. Cleaned all three pcb with liquid cleaner. Cleaned all connectors externally and internally ( holes) using painting brush. Allowed everything to dry.
2. Reconnected
3. Started. This time, went past the Philips logo. I could connect a macbook via HDMI and play youtube videos on the TV for ~1 hours.
4. Using remote, entered service mode and initialized ( factory reset) the TV
5. For 1 hours of proper run, measured voltages. LED+24v was showing properly at 24v, AL+3.3v was at proper 3.3v and the P-ON-H1 was properly at 3.3v
6. After about 1 hrs, the screen shut down. The LED+24v is showing at 6v, AL+3.3v at 3.3v and P-ON-H1 is a 0v. This indicates the main cpu board has turned off the P-ON-H1 signal.
7. Power off, wait for 2 min. Power on... same philips logo and TV shuts down. Problem repeats.
8. Firmware is Code TVNB010_00_PF_XX91_BA PIC code U10_CM08:_40A_C7W_R_02. Did a google search and found no references if this firmware needs any upgrade.
requesting experts next steps to root cause the issue. I suspect the main board is bad and the SMPS is good. What if I manually put a wire from AL+3.3v to P-ON-H1 ? will the TV be on or is it risky for the main cpu board ?
I am attaching the service manual for this TV
21pt5420,ch.l01.2 philips tv A service menűbe beléptem,de már kilépni nem tudok!
Sziasztok Adott a címben szereplő csoda.Képcső csere után a geometriai méreteket állítottam,sikerült is ,de kilépni már nem tudok a vol+,és pr+ ,főkapcsolóval. Mi a megoldás? Várom segítségeteket.Minden működik,de a sam módból nem tudok kilépni!
Philips 40pfl9705K/02 tápegység hiba
Üdvözlök mindenkit! Segítséget kérnék egy tápegység javításában. A fent nevezett készülékkel küszködök, barbár módon eltörték a tápegység paneljét. Sajnos nincs meg egy fontos darab, ami a led meghajtás kimenő oldalán szerepel. Kutakodva találtam gyenge minőségű fotót, egy ellenállás hiányzik onnan. Kényes helyen van, így próbálkozni nem szeretnék a pótlásával. A készüléknek eredetileg más a hibája, így nagy segítség lenne ha nem kellene emiatt tápegységet vásárolni. Ha valakinél lenne egy ilyen, ehhez hasonló készülék amiben ez a tápegység szerepel, kérem nézze meg a hiányzó értéket. Tápegység típusa: FSP253-4FS01 2722 171 90258 Köszönettel, Jimmy
Philips 20PT1542 CHASSISL6 nem ál meg csatorna keresésnél.Megoldva.
Szevasztok Hozták ezt a fentebb leirt tv t,csatorna keresésnél,nem ál meg a megtalált csatornán hanem tovább megy. Az5100 ás AFC tekercsben a kondit helyettesitettem külsővel ,de semmi változás.Valami segitség kellene a hiba feltárásához.
