PHILIPS CHASSIS PTV500 SERIES
1.3 MB
PHILIPS CHASSIS PTV500 SERIES service manual (1st page)
Preview of PHILIPS CHASSIS PTV500 SERIES [1st page]
PHILIPS CHASSIS PTV500 SERIES service manual (2nd page)
Preview of PHILIPS CHASSIS PTV500 SERIES [2nd page]
    PHILIPS CHASSIS PTV-500 PTV500 SERIES PTV 500
Philips 40PFL7007K/12 does not power on - Chassis QFU1.1E LA
Hi everybody, I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board. What I have tried… Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate. And here comes what is not clear to me. 1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode? 2. Can I somehow check if the PSU is working? May be by activating some pin? 3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?.... What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms. The service manual is on this link: http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html Thanks Martin
Philips 58PUS7304/12 háttér látszik
A tárgyban szereplő tv-nek szinte minden led látszik a képen. Diffúzorok nincsenek lepotyogva fólia sem hiányzik belőle, én bontottam meg először a tv-t. Led driver PF7904S. Led áram csökkentésével javulnak a helyzet? Ha igen ennél hogy tudom csökkenteni?
Köszönöm Balázs
Megoldás: tettem bele még egy diffúzor fóliát és tökéletes lett. Egy 65" Samsung fóliáját vágtam erre a méretre
Philips Fl 4.26 Képe egy pontba megy el a tetején színes visszafutási csík bekapcsoláskor SOS
Köszi a segítséget!
Philips FTR9965 plazma tuner a tápja nem indul
Szisztok! Segítséget szeretnék van egy flat tv tuner aminek a tápja hol megy hol nem, de most már egyáltalán nem megy, csak kapcsolgat. Mc44603 ic van a tápban. Keresek rajzot, vagy ötletet hogy mi lehet a hiba, kondikat cseréltem de semmi. Elvileg minden jó csak nem indul, a piros standby LED villog. Valószínű máshol lehet talán a probléma. Imre
